Wired Intelligent Edge
  • 1.  White Screen after logging into Web GUI - Procurve 2530, 24 port switch
    Posted Feb 17, 2021 03:37 AM
    I have a brand new HP Procurve 24 Port POE Switch, I have configured using putty (within managers profile) IP address and and so on. When I try to go on the web GUI, within Chrome I enter in credentials and the box remains, I have verified the password to be correct as I can logon to Putty with the same creds.
    When I use IE (yes, I know...) When I enter the creds, after entering all I get is a white screen.
    I have tried Edge, and get the same results as Chrome
    I spoke to Aruba support in the UK yesterday they seemed to think this maybe because of a bug in the firmware, and then tried to upgrade it, however the agent wasn't successful, so then passed to a colleague here in Germany that stated 'It's up to you to upgrade the firmware' Even after I said I can't get through the credentials screen on Chrome, IE or Edge.
    Can anyone assist?
  • 2.  RE: White Screen after logging into Web GUI - Procurve 2530, 24 port switch
    Posted Feb 17, 2021 04:22 AM
    Are you able to console the switch?
    If yes what are you seeing in 'show log'
    Thanks!
  • 3.  RE: White Screen after logging into Web GUI - Procurve 2530, 24 port switch
    Posted Feb 18, 2021 11:25 PM
    @StuinDresden Hi, Can you try  clearing the browser cache and try enabling pop-up blocker.
  • 4.  RE: White Screen after logging into Web GUI - Procurve 2530, 24 port switch
    Posted Oct 11, 2024 10:27 AM
    @StuinDresden,
    Since you can log in via PuTTY, the credentials should be correct, but the persistent login box and white screen suggest there may be a firmware bug or browser compatibility issue.
    Have you tried clearing your browser cache or using a different device
