Whitelisting Lapton/mobile phones
  • 1.  Whitelisting Lapton/mobile phones
    Posted Aug 19, 2021 11:07 AM
    Dear All,
    Is whitelisting of laptop/device is possible in aruba controller? Can someone give me a manual or instruction on how to do it or if there is an alternative way please give me.
    Thank you!
    Christoper Ian de Alday
  • 2.  RE: Whitelisting Lapton/mobile phones
    Posted Aug 23, 2021 10:59 AM
    That question is unclear, as it can mean different things and also is dependent on the authentication you select, but the answer probably is yes. Please work with your Aruba partner to discuss what you want to, then create a proper design that matches your requirements, and then implement it.
