Original Message:
Sent: Mar 23, 2025 12:37 AM
Subject: Why is there a VLAN field in show ip route command ?
Usually on Layer 3 switches, VLANs are used as SVI (Switch Virtual Interface). Those interfaces are logical interfaces tied to a VLAN which have an IP Address assigned. Those interfaces are acting as routed interfaces on the switch. In your case, the next hop for that route is the SVI Interface for VLAN 4001 and all OSPF communications and routing decisions are happening over that SVI.
According to your routing table, VLAN 4001 is the only Layer 3 interface participating in routing on that certain switch, or at least it is the interface used to reach all next hops in that table. So that means all the OSPF routes are learned through VLAN 4001 in that case. The SVI management which you have configured is doing the routing and not any other Layer-3 interface. So in your case, even though you are calling it the Management VLAN, you are using it for actual routing, which is fine if configured intentionally, but it does mean that any Layer 3 routing traffic will be seen on that VLAN as well.
Shpat | ACEP | ACMP | ACCP | ACDP
Just an Aruba enthusiast and contributor by cases
If you find my comment helpful, KUDOS are appreciated.
Original Message:
Sent: Mar 21, 2025 11:26 AM
Consider the output below. It might look like a silly question, but why is there a VLAN field in the output of "show ip route" command ?
Unless I'm mistaken, VLANs are purely layer 2, so why show that field here ? VLAN 4001 is our management VLAN, why is it cited for all routes ?
Switch# sh ip route
Destination Gateway VLAN Type Sub-Type Metric Dist.
0.0.0.0/0 10.255.255.254 4001 ospf External2 10 110
10.100.0.0/24 Management 4001 connected 1 0
10.100.2.0/24 10.255.255.254 4001 ospf IntraArea 101 110
10.100.10.0/24 10.255.255.200 4001 ospf IntraArea 101 110
10.100.10.0/24 10.255.255.195 4001 ospf IntraArea 101 110
10.200.0.0/16 10.255.255.254 4001 ospf External2 10 110
10.111.100.0/24 10.255.255.200 4001 ospf IntraArea 101 110
