Why my IAP-315-RW cannot broadcast wifi
This thread has been viewed 19 times
  • 1.  Why my IAP-315-RW cannot broadcast wifi
    Posted Jul 11, 2024 04:10 AM
    I have a lab with IAP-315-RW device, when I plugged it with PoE the left LED light with the exclamation mark icon is green blinking but the right LED light with wifi icon doesn't show anything, it just off since I plugged in the PoE, I don't know if there is any problem with my device or not, or any issue with the license. Any help in getting this device working would be highly appreciated. Thank you.
  • 2.  RE: Why my IAP-315-RW cannot broadcast wifi
    Posted Jul 11, 2024 04:36 AM
    Are you sure that the network where the AP is plugged in has DHCP enabled, so the AP will get an IP address?
    Could it be that the AP has been used with a controller? In that case, try a factory reset (pinhole button, keep pressed while connecting power, wait till fast-flashes, then release the reset button). After that, the AP should return to the Instant firmware.
    If the power led is blinking green, it's still in it's boot/initialization process. If you have a console cable (requires a special USB to 4 pin console cable), what's being shown on the serial console may provide more info.
  • 3.  RE: Why my IAP-315-RW cannot broadcast wifi
    Posted Jul 11, 2024 10:53 PM
    Cause I didn't see the AP broadcast Wifi, I used the Aruba Virtual Mobility Controller to provide DHCP to the AP. The AP had IP(192.168.10.1) from DHCP of the VMC and the dashboard of VMC webui showed an AP-315 connected, but the Wifi LED light on the AP still off and it's cannot broadcast wifi. This is my first time with Aruba products so can you help solve it. Thank you.
  • 4.  RE: Why my IAP-315-RW cannot broadcast wifi
    Posted Jul 12, 2024 04:23 AM
    VMC is not needed with just the Instant AP, it has a built-in virtual controller. Can you show a screenshot of what you see where the AP-315 is connected? That may let us know what you actually have. If you can explain in addition where you got the AP from and what you intent to do with it, that may help.
  • 5.  RE: Why my IAP-315-RW cannot broadcast wifi
    Posted Jul 12, 2024 06:33 AM
    This is the dashboard in my ArubaOS-VMC and the AP detail, if you can support anything please reply to me soon. Thank you.
  • 6.  RE: Why my IAP-315-RW cannot broadcast wifi
    Posted Jul 15, 2024 04:47 AM
    Is there a specific reason that you have VMC? The IAP-315-RW can be operated without controller in Instant mode (VC), which is much simpler at small scale (like with 1 or few APs).
    If you want to use VMC, did you configure a WLAN? Without further configuration, there is no default WLAN.
