WiFi disconnecting randomly AP 515 with Clearpass
This thread has been viewed 49 times
  • 1.  WiFi disconnecting randomly AP 515 with Clearpass
    Posted Sep 06, 2024 05:48 AM
    Many clients complains about wifi which is keep disconnecting randomly without no reason.
    i run 5 aruba ap 515, and created 2 ssid (one is for guest with clearpass authentication) an other with password.
    So, the ssid with password is working perfectly but the second one working with Clearpass keeps loosing wifi connection
    Im i missing something with my ssid configuration with clearpass ?
    Thanks in advance
    Ali AMOKRANE
  • 2.  RE: WiFi disconnecting randomly AP 515 with Clearpass
    Posted Sep 06, 2024 07:45 PM
    do you mean when the clients connect to the guest SSID they get disconnected? do they go through  authentication  and then they get disconnected or before?
  • 3.  RE: WiFi disconnecting randomly AP 515 with Clearpass
    Posted Sep 10, 2024 09:52 AM
    Hi Ariyap,
    The clients connect perfectly whithin approxamituvly 10min (sometimes more or less), and they get disconnected, and after few momments, they get reconnected.
    It's really a weird situation
  • 4.  RE: WiFi disconnecting randomly AP 515 with Clearpass
    Posted Sep 10, 2024 07:18 PM
    please list the radius attributes you are sending back in your enforcement profiles?
  • 5.  RE: WiFi disconnecting randomly AP 515 with Clearpass
    Posted Sep 10, 2024 07:26 PM
    Ali,
    Is it possible you don't have a working "MAC Caching" service in ClearPass and user devices get disconnected each time they attempt to roam between access points or get band steered between radios?
    Brad
  • 6.  RE: WiFi disconnecting randomly AP 515 with Clearpass
    Posted Sep 11, 2024 10:34 AM
    Brad,
    The MAC Caching is working fine. (all users get connected without captive portal authentication once they authentified already); Give an exemple : User connect today with his credentials i've created already, everything working fine, let's say in the following day, the same user connect perfectly without typing anything.
    But my issue is when the user is connected, after 10min (appromaxivly), he is disconnected from wifi, and get reconnected after few moments. which is really annoying
  • 7.  RE: WiFi disconnecting randomly AP 515 with Clearpass
    Posted Sep 11, 2024 10:36 AM
    Ariyap,
    I'll share with you the attributes tomorrow, i'm out of the office right now.
    Thank you
  • 8.  RE: WiFi disconnecting randomly AP 515 with Clearpass
    Posted Sep 12, 2024 09:34 AM
    I didn't see any info on which firmware release you are on but in AOS 8 there is 8.10.0.14 just released and has AP515 specific fixes.
  • 9.  RE: WiFi disconnecting randomly AP 515 with Clearpass
    Posted Sep 13, 2024 03:50 AM
    Ascott,
    The issue not fixed in this update. I'm alredy in 8.10.0.13, and in the latest (8.10.0.14) in the resolved issue : nothing mentionned
  • 10.  RE: WiFi disconnecting randomly AP 515 with Clearpass
    Posted Sep 13, 2024 10:41 AM
    Edited by ascott Sep 13, 2024 10:45 AM
    I see what you are say.  The fix was in .07 release.  Gotcha.
    And wanted to point out a few things in the release notes as resolved issues related to 515s:
  • 11.  RE: WiFi disconnecting randomly AP 515 with Clearpass
    Posted Sep 14, 2024 05:58 AM
    What i'm reading that the fix was in the 8.10.0.13 (not in the 8.10.0.7 which is the start version issue if i understand well). The thing is i already update to the 8.10.0.13 and still have the issue and in the last update 8.10.0.14, they did not mention this issue as they think it's resolved in the 8.10.0.13 release which is still on
