1. Make sure you import the Root and any Intermediate certs into the trust list
2. Combine the Wildcard cert with the Root and Intermediate if you can
a. Some device do not trust godaddy intermediate certs so it help to combine the full trust chain.
b. Digicert has an easy to understand how-to " http://www.digicert.com/ssl-support/pem-ssl-creation.htm "
3. Then you just import the newly created .pem file to CPPM
Creating a .pem with the Entire SSL Certificate Trust Chain
- Log in to download your Intermediate (DigiCertCA.crt), Root (TrustedRoot.crt), and Primary Certificates (your_domain_name.crt) from within your DigiCert Customer Account.
- Open a text editor (such as wordpad) and paste the entire body of each certificate into one text file in the following order:
- The Primary Certificate - your_domain_name.crt
- The Intermediate Certificate - DigiCertCA.crt
- The Root Certificate - TrustedRoot.crt
Make sure to include the beginning and end tags on each certificate. The result should look like this:
-----BEGIN CERTIFICATE-----
(Your Primary SSL certificate: your_domain_name.crt)
-----END CERTIFICATE-----
(Your Intermediate certificate: DigiCertCA.crt)
(Your Root certificate: TrustedRoot.crt)
Save the combined file as your_domain_name.pem. Your .pem file is now ready for use.
Creating a .pem with the Server and Intermediate Certificates
- Log in to download your Intermediate (DigiCertCA.crt) and Primary Certificates (your_domain_name.crt) from within your DigiCert Customer Account.
- With a text editor (such as wordpad), copy and paste the entire body of each certificate into one text file in the following order:
Save the combined file as your_domain_name.pem. Your .pem file should be ready for use.
Ref- http://www.digicert.com/ssl-support/pem-ssl-creation.htm
