  • 1.  Wildcard SSL certificate for Aruba home lab envirement
    Posted Oct 30, 2018 07:34 AM
    hello Folks,
    my home lab is all about: Clearpass VM 6.4 and 2x7010 Mobility Controllers OS6.5 . in the future I'll migrate to AOS 8 and set up a VMM.
    I don't need to see any more SSL certificate error and related issues for Guest users and admin https connections.
    any way to get a free Wildcard certificate for a home lab, or buy otherwise?
    is this will work for my current and future plan?
    please, I'm open to all your suggestions.
  • 2.  RE: Wildcard SSL certificate for Aruba home lab envirement
    Posted Oct 30, 2018 08:12 AM
    You would need to purchase one.
  • 3.  RE: Wildcard SSL certificate for Aruba home lab envirement
    Posted Oct 30, 2018 08:41 AM
    So a Wildcard SSL Certificate will work for my Clearpass and both current MC controllers and my future VMM, right?
    thank you!
  • 4.  RE: Wildcard SSL certificate for Aruba home lab envirement
    Posted Oct 30, 2018 08:47 AM
    It's not great security practice, but for a lab, yes.
  • 5.  RE: Wildcard SSL certificate for Aruba home lab envirement
    Posted Oct 30, 2018 08:49 AM
    Awesome ! thank you so much
  • 6.  RE: Wildcard SSL certificate for Aruba home lab envirement
    Posted Nov 01, 2018 02:42 AM
    Hello Tim,
    A question prompted in my mind, As you know, I'll need to generate a CSR for signature, from which device I should generate the CSR? the master controller, Local controller, or clearpass?
    I'm still learning about Certificates,
    regards,
    thanks,
  • 7.  RE: Wildcard SSL certificate for Aruba home lab envirement
    Posted Nov 01, 2018 07:31 AM
    ClearPass or your laptop.
  • 8.  RE: Wildcard SSL certificate for Aruba home lab envirement
    Posted Nov 01, 2018 09:15 AM
    Hi Tim,
    i understand that I need to create CSR from Clearpass or my laptop using OpenSSL.
    thank you!
