Skip main navigation (Press Enter).
Log in
Toggle navigation
Search Options
Log in
Home
Discussion Forum
Support
Documentation Portal
Support Knowledge Base
HPE Networking Support Portal
Live + Virtual Events
Webinar Archive
Upcoming Events
News
Technical Blog
ACEX Hall of Fame
MVP Program
Become a Member
Search Options
Community Home
Discussion
123K
Members
3.3K
Back to discussions
Expand all
Collapse all
sort by most recent
sort by thread
will 802.1x work on Controller without PEF Licesne
rafik.fawzy
Mar 26, 2015 08:29 AM
Will 802.1x Authentication against a Radius Server work, without the PEF Licesne ?
cappalli
Mar 26, 2015 08:30 AM
Yes,, but all users will receive te same access Thanks, Tim
rafik.fawzy
Mar 26, 2015 08:32 AM
Thanks for your reply, So i don't need to change any user role either per-authentication or post-authentication ...
cappalli
Mar 26, 2015 08:34 AM
Yes. The role options in the AAA profiles will be greyed out. Everyone essentially goes into the authenticated ...
1.
0
Kudos
rafik.fawzy
Posted Mar 26, 2015 08:29 AM
Reply Privately
Options Dropdown
2.
RE: will 802.1x work on Controller without PEF Licesne
0
Kudos
cappalli
Posted Mar 26, 2015 08:30 AM
Reply Privately
Options Dropdown
Tim
3.
0
Kudos
rafik.fawzy
Posted Mar 26, 2015 08:32 AM
Reply Privately
Options Dropdown
per-authentication or post-authentication ?
I just map the Controller to the correct Radius Server and it should work ?
Best Regards,
Rafik Soliman
4.
0
Kudos
cappalli
Posted Mar 26, 2015 08:34 AM
Reply Privately
Options Dropdown
Yes. The role options in the AAA profiles will be greyed out. Everyone essentially goes into the authenticated role on the back end.
Just send an access accept on your RADIUS server.
Tim
New Best Answer
This thread already has a best answer. Would you like to mark this message as the new best answer?
Related Content
cannot apply authenticated role without PEF
Ronin101
Added Sep 10, 2023
Discussion Thread
23
Missing Authenticated Role without PEF License
mtraettner
Added Aug 23, 2013
Discussion Thread
5
RADIUS Authentication
RR8
Added Apr 04, 2012
Discussion Thread
13
How to limit Bandwidth per User or per SSID without the PEF License ?
rafik.fawzy
Added Jun 01, 2015
Discussion Thread
3
RE: cannot apply authenticated role without PEF
Owais101
Added Sep 11, 2023
Library Entry
Copyright 2024. All rights reserved.
Powered by Higher Logic
