Comware
Will adding a VRF (VPN-instance) on a 5820 break current non-VRF routes?
  • 1.  Will adding a VRF (VPN-instance) on a 5820 break current non-VRF routes?
    Posted Mar 06, 2015 07:36 AM
    Unfortunately I dont have a spare unit to test this on but if I add a VRF (VPN-intsance) lets say for MGMT will that somehow break current non-VRF routes?
    Or will they be "unnamed" and continue to function along with this new VRF?
  • 2.  RE: Will adding a VRF (VPN-instance) on a 5820 break current non-VRF routes?
    Posted Mar 10, 2015 05:20 AM
    sure, you can consider the existing routing table as the first vrf, so making another vpn-instance (vrf) does not have any impact on the existing routing table,
    hth,Peter
