You responded to a very old discussion on wired ports on APs. Please open a new discussion, and explain what you have set up.
To see (wired) clients in a controller, you would need to have an untrusted ports/VLAN, and possibly tunnel the client. But without further understanding of what you set up, it's hard to guess what's wrong or if it maybe even is expected.
Original Message:
Sent: Aug 27, 2024 04:41 PM
Subject: Wired client not visible in aruba central
Hi Derek, I have a 2930F switch and a 7005 Aruba Controller running 8.12.0.2.
The DHCP is done by the controller, and I have some devices connected wired to the switch, but they do not appear at the wired devices dashboard on the WebUI of the controller.
Do you know what do I have to do to make the controller display the wired devices also?
Thanks.
Original Message:
Sent: Jul 14, 2020 08:10 AM
Enabling dhcp-snooping will allow you to see wired client ip's.
