Indeed you cannot authenticate clients on your uplink port, just on a downlink port.
If you can create a mesh to another AP, you may be able to change the eth0 port to a downlink port and run a wired captive portal on it. But better/easier to get APs with multiple ethernet interfaces.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Apr 30, 2025 03:54 AM
Subject: Wired cloud guest portal on eth0
I am testing with a 303 model, which only has one port. It is possible that you simply cannot enable an authentication service on an uplink port, but I wanted to test the possibility. I hope someone can figure out how it can be done because it would help me quite a bit in my infrastructure.
Best regards, and thanks for your reply
Original Message:
Sent: Apr 30, 2025 12:15 AM
what AP model are you using for this? generally you should not change E0 wired profile a sit is the uplink for the AP.
But you can create E1-E4 port profile and enable Cloud Guest
Here I am using AP505H that has 4x Ethernet ports and this is for E3.
Original Message:
Sent: Apr 29, 2025 07:10 PM
Hi.
I know that is posible to have a wired profile for guest access on my access points, but I'm having problems trying to configure it from Aruba Central. I want to configure a Guest Cloud Portal working on a WLAN and Eth0. On WLAN i have no problem, but on Eth0 I get the IP address but I'm no having any authentication procedure. I have a specif local dhcp scope for this service. This is my configuration:
ip dhcp CP
server-type Local
server-vlan 10
subnet 192.168.10.0
subnet-mask 255.255.255.0
default-router 192.168.10.1
dns-server 8.8.8.8
wired-port-profile default_wired_port_profile
switchport-mode trunk
allowed-vlan all
native-vlan 10
no shutdown
access-rule-name default_wired_port_profile
speed auto
duplex full
no poe
type guest
auth-server AS1_#guest#_
auth-server AS2_#guest#_
captive-portal external profile 07Eventos_#guest#_
no dot1x
radius-accounting
radius-interim-accounting-interval 5
set-role-pre-auth 07Eventos_#guest#_
enet0-port-profile default_wired_port_profile
wlan ssid-profile testCP
enable
index 0
type guest
essid testCP
utf8
wpa-passphrase 3a762eeda709dda7de709074887564a0dce068ed339e3254
opmode wpa3-sae-aes
max-authentication-failures 0
vlan 10
rf-band all
mac-authentication
mac-authentication-delimiter :
mac-authentication-upper-case
dtim-period 1
broadcast-filter arp
radius-accounting
dmo-channel-utilization-threshold 90
local-probe-req-thresh 0
max-clients-threshold 128
Any idea why is not working?
Thank you in advanced
