Cloud Managed Networks
  • 1.  Wired cloud guest portal on eth0
    Posted Apr 29, 2025 07:10 PM
    Hi.
    I know that is posible to have a wired profile for guest access on my access points, but I'm having problems trying to configure it from Aruba Central. I want to configure a Guest Cloud Portal working on a WLAN and Eth0. On WLAN i have no problem, but on Eth0 I get the IP address but I'm no having any authentication procedure. I have a specif local dhcp scope for this service. This is my configuration:
    ip dhcp CP
     server-type Local
     server-vlan 10
     subnet 192.168.10.0
     subnet-mask 255.255.255.0
     default-router 192.168.10.1
     dns-server 8.8.8.8
    wired-port-profile default_wired_port_profile
     switchport-mode trunk
     allowed-vlan all
     native-vlan 10
     no shutdown
     access-rule-name default_wired_port_profile
     speed auto
     duplex full
     no poe
     type guest
     auth-server AS1_#guest#_
     auth-server AS2_#guest#_
     captive-portal external profile 07Eventos_#guest#_
     no dot1x
     radius-accounting
     radius-interim-accounting-interval 5
     set-role-pre-auth 07Eventos_#guest#_
    enet0-port-profile default_wired_port_profile
    wlan ssid-profile testCP
     enable
     index 0
     type guest
     essid testCP
     utf8
     wpa-passphrase 3a762eeda709dda7de709074887564a0dce068ed339e3254
     opmode wpa3-sae-aes
     max-authentication-failures 0
     vlan 10
     rf-band all
     mac-authentication
     mac-authentication-delimiter :
     mac-authentication-upper-case
     dtim-period 1
     broadcast-filter arp
     radius-accounting
     dmo-channel-utilization-threshold 90
     local-probe-req-thresh 0
     max-clients-threshold 128
    Any idea why is not working?
    Thank you in advanced
  • 2.  RE: Wired cloud guest portal on eth0
    Posted Apr 30, 2025 12:15 AM
    what AP model are you using for this? generally you should not change E0 wired profile a sit is the uplink for the AP.
    But you can create E1-E4 port profile and enable Cloud Guest
    Here I am using AP505H that has 4x Ethernet ports and this is for E3.
  • 3.  RE: Wired cloud guest portal on eth0
    Posted Apr 30, 2025 03:54 AM
    I am testing with a 303 model, which only has one port. It is possible that you simply cannot enable an authentication service on an uplink port, but I wanted to test the possibility. I hope someone can figure out how it can be done because it would help me quite a bit in my infrastructure.
    Best regards, and thanks for your reply
  • 4.  RE: Wired cloud guest portal on eth0
    Posted Apr 30, 2025 04:40 AM
    Indeed you cannot authenticate clients on your uplink port, just on a downlink port.
    If you can create a mesh to another AP, you may be able to change the eth0 port to a downlink port and run a wired captive portal on it. But better/easier to get APs with multiple ethernet interfaces.
  • 5.  RE: Wired cloud guest portal on eth0
    Posted Apr 30, 2025 04:49 AM
    Ok, I understand. Thanks for the reply.
