  • 1.  Wired enforcement for Access point (tagged and untagged vlan)
    Posted Feb 22, 2018 09:31 AM
    Hi all,
    I would like to enforce on my switch AOS 2930 the specific port config which will be used when I'll plug Aruba APs:
    Untagged vlan: Vlan for Access Points
    Tagged vlanS: all my users vlans (Corporate, Guest, etc.)
    User trafic won't be tunneled to Wireless controler.
    How can I do that?
    Shall I configure Aruba User-role? In that case, I don't see how, in a specific role I would configure several tagged vlans...
    OR
    Shall I use classic vlan enforcement in that scenario?
    I guess it's the second method but I'll be sure of that
    Thanks for your help
    Fred
  • 2.  RE: Wired enforcement for Access point (tagged and untagged vlan)
    Posted Feb 22, 2018 09:52 AM
    Aruba campus APs should simply sit in a user subnet, just like any other client device. There is no need tag any VLANs.
    Take a look at the ClearPass Solution Guide for Wired Policy Enforcement for configuration examples.
  • 3.  RE: Wired enforcement for Access point (tagged and untagged vlan)
    Posted Feb 22, 2018 10:06 AM
    Hi Tim,
    your solution doesnt work for us.
    What we want to do:
    When an AP is plugged to our AOS 2930F switches, CPPM must enforce:
    - vlan AP untagged
    - vlan Corporate tagged
    - vlan Guest tagged
    - vlan Printer tagged
    - vlan blabla tagged
    Even if you place your AP in another vlan, I don't see how to enforce a tagged vlan via CPPM (an moreover, how to enforce several tagged vlan)
    I read wired guide and didn't find a solution too
    Kind regards,
    Fred
  • 4.  RE: Wired enforcement for Access point (tagged and untagged vlan)
    Posted Feb 22, 2018 10:08 AM
    You said the APs are tunneling to a controller. There should be no tagged VLANs on a campus AP.
  • 5.  RE: Wired enforcement for Access point (tagged and untagged vlan)
    Posted Feb 22, 2018 10:10 AM
    No,
    I said:  User trafic won't be tunneled to Wireless controler.
    It'll be locally switched. That's why I need tag
    Fred
  • 6.  RE: Wired enforcement for Access point (tagged and untagged vlan)
    Posted Feb 22, 2018 10:13 AM
    OK, sorry misread. You cannot use RADIUS assigned user roles then. You’d have to use device-profiles with LLDP to map the user role.
  • 7.  RE: Wired enforcement for Access point (tagged and untagged vlan)
    Posted Feb 22, 2018 10:17 AM
    OK,
    Do you have any doc or example of how to do this?
    That 'll be great
    Fred
  • 8.  RE: Wired enforcement for Access point (tagged and untagged vlan)
    Posted Feb 22, 2018 10:23 AM
    I don’t sorry. Probably a better question for the switching group.
  • 9.  RE: Wired enforcement for Access point (tagged and untagged vlan)
    Posted Apr 23, 2018 10:36 PM
    I used this guide:
    https://community.arubanetworks.com/t5/Wired-Networks/Returning-multiple-tagged-VLANS-and-untagged-VLAN-from-ClearPass/ta-p/413955
    Tested with CPPM 6.7.2 and 2930M on 16.05 and 2920 on 16.05
    I used MAC auth with profiling. The AP profile gets all the additional tagged VLANs
  • 10.  RE: Wired enforcement for Access point (tagged and untagged vlan)
    Posted Apr 24, 2018 01:00 AM
    Have you checked device profile?
    Please check below if it helps:
    http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/RA/16-01/webhelp/content/ch10.html
