  • 1.  Wireless AP 515s drop intermittently
    Posted Nov 01, 2024 01:14 PM
    I have 29 Aruba 515s used at my company. They are all powered via PoE. Due to the size of the building we have multiple Cisco switches being used to run the APs, with the main switch being a Cisco 9300x.
    We got the devices all set up and everything appears to be working fine. However, I will check the controller and see there are 2 APs down. I will disconnect the ethernet connection at the patch panel and reconnect, and the device will be up. Later I will check and 2 different APs down. The APs that go down are always different, and they will be in different locations around the building (meaning they are connected to different switches).
    We have done a few different things for troubleshooting, as we initially were getting a 2r flag. The power limit has been removed for all the APs. We tried using different cables and this made no difference.
    Has anybody else seen this or have something else we can try?
  • 2.  RE: Wireless AP 515s drop intermittently
    Posted Nov 01, 2024 07:30 PM
    What PoE is being negotiated by the APs?  Do you have LLDP enabled?  Have you opened a case with TAC?
    Carson Hulcher, ACEX#110
  • 3.  RE: Wireless AP 515s drop intermittently
    Posted Nov 08, 2024 09:41 AM
    I will attach the statics from one of my APs in this post. I opened a case with TAC before and they told me how to enable LLDP. Let me know if you have any other questions. Appreciate the help!
  • 4.  RE: Wireless AP 515s drop intermittently
    Posted Nov 08, 2024 09:44 AM
    *In case the photo did not upload properly*
    (FRK-MC) *[mynode] #show ap power-mgmt-statistics ap-name ap-15
    AP Power Mgmt Status, Last update at 2024-11-08 08:41:36
    Attr                Value
    LLDP Granted Power  Eth 0: 26.5 Eth 1: 0.0
    LLDP Request Power  Eth 0: 26.5 Eth 1: 0.0
    Temperature         Highest temperature: 72°C, Lowest temperature: 54°C, Curre      nt temperature: 61°C
    Power Supply        POE-BT
    USB Status          USB Knob: Auto, USB Status: Enabled
    PSE Status          N.A.
    ETH Status          Eth 0:Enabled. Eth 1:Enabled.
    G-radio Chain       2*2
    G-radio Enable      Enabled
    G-radio Power       Full Power
    A-radio Chain       4*4
    A-radio Enable      Enabled
    A-radio Power       Full Power
    CPU Throttle        100%
    Power Consumption   12.2W
    IPM Enable          Disabled
    ITM Status          Not Supported
  • 5.  RE: Wireless AP 515s drop intermittently
    Posted Nov 08, 2024 09:58 AM
    What version of AOS are you running?  Does the AP respond to ping while the issue is occurring?
    I'd recommend opening a case with TAC to troubleshoot.
  • 6.  RE: Wireless AP 515s drop intermittently
    Posted Nov 08, 2024 10:58 AM
    Running AOS version 8.7. The AP does respond to pings when its showing as down in the console. Looking at the AP itself it shows a blinking green LED when the issue occurs.
  • 7.  RE: Wireless AP 515s drop intermittently
    Posted Nov 08, 2024 11:10 AM
    Ah.  I would highly recommend upgrading to at least the latest 8.10 release and see if the issue continues.
  • 8.  RE: Wireless AP 515s drop intermittently
    Posted Nov 28, 2024 11:10 AM
    Did you upgrade to 8.10? If so, which dot release and did it fix your issue?
    Nathan K
