Wireless Edge Module (J9051A) not adopting RP's on edge switches
  • 1.  Wireless Edge Module (J9051A) not adopting RP's on edge switches
    Posted May 30, 2008 07:54 AM
    I have a Wireless edge mod in a 5312 core switch. My RP's adopt everytime when I plug them into this, but never adopt when plugging them into an edge switch.
    I have tagged my connections to the edge switches to the correct VLANS, and untagged the ports on the switches that the RP's are plugged into but to no avail.
    I have patched a machine into one of these ports and I can ping and communicate with other things on this VLAN but the RP's still dont adopt.
    Is there any way I can see where they are falling over, or any example configs to help us go forward?
    Thanks in advance
  • 2.  RE: Wireless Edge Module (J9051A) not adopting RP's on edge switches
    Posted May 30, 2008 11:31 AM
    hi Stewart
    invalid model number your procurve switch 5312
    and don't use J9051A module on 5300 switch
    j9051A module only use 5400 switch
    so your switch 5400 please send me core and edge switch show tech print
    cenk
  • 3.  RE: Wireless Edge Module (J9051A) not adopting RP's on edge switches
    Posted May 31, 2008 04:53 AM
    Hiya.
    My model number is a 5412...sorry. However, I have fixed my problem. The issue was I had pre-staged my switches and already created the 2100 VLAN. My switches were then adding the readio ports to VLAN 2101.
    If I delete my pre-created VLAN 2100, and make sure the lldp auto-provision line points to VLAN 2100, the radio ports adopt.
    Thanks for you help.
