I have few 655 APs that are managed by Aruba Central. In one particular SSID I have enabled Opportunistic Key Caching (OKC), 802.11r and 802.11k
MDID: is set to 1 and RRM Quiet IE: is disabled in the fast roaming option.
Now my question is If I disable all so will the roaming get disabled in the SSID and will it effect the users If I do it while in production or do I need a downtime?
Thanks.
