  • 1.  Wl110 and WEP Problems under XP professional
    Posted Dec 02, 2002 05:41 PM
    I have a WL110 PC-Card and when I try to connect via WEP encryption to an access point, some funtions do not work. For example I can't send emails but recieve emails if WEP (either with 64bit or 128bit keys)is activated. Also filetransfers to other computers do not work.
    If WEP is disabled anything works fine. There are no error-messages or something else. The connection information doesn't show any error either. Pleas can you give me a hint how to solve that problem....
    Alex
  • 2.  RE: Wl110 and WEP Problems under XP professional
    Posted Dec 03, 2002 03:46 PM
    When you disable WEP...this has been done on both ends (the access point and WL110 PC-Card)?
    =oI
    Respectfully,
    -NeoNemo13
  • 3.  RE: Wl110 and WEP Problems under XP professional
    Posted Dec 07, 2002 04:14 PM
    Dear Robert,
    sure both the WLan card and the access point has been set to WEP or WEP disabled at the same time. That is what dissapoints me. I still have no solution for this problem and I'm not going to open up a hotspot for wardrivers :)
    Alex
  • 4.  RE: Wl110 and WEP Problems under XP professional
    Posted Dec 12, 2002 10:59 PM
    Sounds like something in your pop3 settings or protocol is not getting treated correctly when encrypted. All I can say is check the following support location to make sure you are using the latest drivers and/or firmware (if any is available). A firmware upgrade or a Windows update is probably your best bet.
    http://h18004.www1.hp.com/support/files/networking/wlan/WL110.html
  • 5.  RE: Wl110 and WEP Problems under XP professional
    Posted Dec 12, 2002 11:05 PM
    By the way, you might also check out this other thread that talks about WL200 and XP:
    http://forums.itrc.hp.com/cm/QuestionAnswer/1,,0x92c199d0caddd61190050090279cd0f9,00.html
