  • 1.  WLC software 6.5.4.9 vrrp not working and how to debug issues
    Posted Jun 16, 2020 06:22 PM
    Hi
    We have tan customer with Aruba7210 in master-standby mode.
    Now, both WLCs are in Master mode in excep 2 VLAN's.
    Now, I need Your help - how can I debug  and set logging related to VRRP issues in CLI?
    I've read some discussion and find out that people use command like
    logging level debugging network process vrrpd
    - this is not working so I assume 6.5 does not support it?
    What is the right CLI command to activate vrrp issue debugging?
    Juha-Pekka
  • 2.  RE: WLC software 6.5.4.9 vrrp not working and how to debug issues
    Posted Jun 17, 2020 09:04 AM
    Are the two controllers part of the same VLAN? If not you wont get VRRP to work. VRRP requires that the interfaces you're trying to run VRRP over exist in the same L2 Broadcast Domain.
  • 3.  RE: WLC software 6.5.4.9 vrrp not working and how to debug issues
    Posted Jun 17, 2020 09:47 AM
    Hi
    yes L2 is ik and they can also  ping so L3 and works as well
    mac adresses of each wlc are know on both hosts and switches they are connected on.
    strange issue i’ve not seen before
    L2 exist in one Core switch nexus 5k but are connected on different extenders
    br
    juha-pekka
  • 4.  RE: WLC software 6.5.4.9 vrrp not working and how to debug issues
    Posted Jun 17, 2020 09:40 AM
    This post should give an some idea in what commands to use for debugging vrrp.
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/What-are-all-the-debugging-and-troubleshooting-commands-that-we/ta-p/237761
    Could you share the output of show vrrp <id> statistics as well for the problematic vrrp.
