WPA-Enterprise/TKIP and WPA2-Enterprise/AES - single ssid
  • 1.  WPA-Enterprise/TKIP and WPA2-Enterprise/AES - single ssid
    Posted May 17, 2015 11:56 AM
    I have two question regarding controller configuration:
    1st: I would like to configure simultaneously both WPA/TKIP and WPA2/AES security option on the same ssid. Is it possible? If yes, how can I do that?
    2nd I would like to create a group of APs which will broadcast the same ssid. I would like that my device will consider this group od APs as single BSSID device. Is it possible?
    Mateusz
  • 2.  RE: WPA-Enterprise/TKIP and WPA2-Enterprise/AES - single ssid
    Posted May 17, 2015 12:01 PM
    1) use mixed mode under the SSID encryption settings.
    2) No, this is not possible
    Tim
