  • 1.  WPA2-AES not selectable
    Posted Feb 22, 2021 10:03 PM
    Hi All,
    Is this just me being stupid? (I usually deal with AOS 6.x day to day)...
    On arubaOS 8 (8.7.1.1) on a Virtual MM, I'm trying to create an SSID profile... but for some reason WPA2-AES is not selectable?!
    Has anyone seen this before?
    I'm doing this under a managed network group...
    [Managed Devices]
        [Group]    <---- Applying the SSID here.... Correct place?
           [Controller-1]
           [Controller-2]
    I've got all my AAA profiles in.... (Clearpass settings all configured for RADIUS/TACACS).... 802.1x all configured for CPPM.... MAC Auth all configured for local.... RFC 3567 in also pointing at CPPM. It is pretty much a like for like of my 6.x profiles.... I can guarantee i am clearly just missing a check box somewhere....
    John Kennedy
  • 2.  RE: WPA2-AES not selectable
    Posted Feb 23, 2021 12:50 AM
    I am running exactly the same firmware and I can select it with no issues.
  • 3.  RE: WPA2-AES not selectable
    Posted Feb 23, 2021 04:43 AM
    Edited by jkennedy1983 Feb 23, 2021 04:47 AM
    Thanks for posting :)
    Transpires it is an Edge Chromium / Google Chrome Issue (for me anyways).
    Tried it in IE and it is fine... Looks like IE is still valid for a while yet! :D
    John Kennedy
  • 4.  RE: WPA2-AES not selectable
    Posted Feb 23, 2021 07:33 AM
    Edited by bosborne Feb 23, 2021 07:34 AM
    CAUTION: This is purely a personal guess.
    WPA3 is a requirement for Wi-Fi 6 certification. It is possible that WPA3 can be backward compatible with WPA2-AES but I do not know.
    EDIT: If it was a browser issue, please be sure to open a TAC support case so it can be corrected and others can benefit from a solution.
    Bruce Osborne
