  • 1.  WPA2-PSK SSID erroneously presents captive portal
    Posted May 02, 2019 02:19 PM
    7005 controller running ArubaOS 8.4.0.2. New IAP-315 and prior IAP-215s deployed. iOS 12.x clients.
    Trying to deploy a farily simple WPA2-PSK SSID after upgrading from 6.5.x ArubaOS.
    WPA2-PSK SSID deployed prior to upgrade behaves as expected - no captive portal is triggered or displayed.
    Newly deployed SSID, trying to rely on WPA2-PSK for some reason causes client to display captive portal websheet in iOS (and macOS) ui. Access > Default Role = logon (identical to pre-upgrade WPA2-PSK SSID).
    Unsure why the captive portal is being triggered. Have deleted and created new SSIDs configured identically - no change in client behavior. Have tried different AP groups, wondering if new IAP-315 might be to blame...?
    Any thoughts on how to stop the captive from triggering would be much appreciated.
  • 2.  RE: WPA2-PSK SSID erroneously presents captive portal
    Posted May 02, 2019 02:25 PM
    Isolated the latest, new WPA2-PSK SSID to AP group with *only* previously deployed IAP-215s. No change in behavior - captive portal web sheet still triggers on client after successful authentication.
  • 3.  RE: WPA2-PSK SSID erroneously presents captive portal
    Posted May 02, 2019 02:40 PM
    Also created new, open SSID in ap group limited to IAP-315. Same result. Client joins. But captive portal web sheets still presented. Thinking it might be access role related...
  • 4.  RE: WPA2-PSK SSID erroneously presents captive portal
    Posted May 02, 2019 02:49 PM
    You shout set the initial role in the aaa profile to authenticated. Logon role will trigger a captive portal page.
  • 5.  RE: WPA2-PSK SSID erroneously presents captive portal
    Posted May 02, 2019 03:07 PM
    Also check with show user-table which role is assigned to the user/device
  • 6.  RE: WPA2-PSK SSID erroneously presents captive portal
    Posted May 02, 2019 04:58 PM
    Seems to have done the trick.
    Thanks so much.
