is wpa3 enterprise backwards compatible ?
When using the opmode wpa3-aes-gcm-256 with opmode transistion enabled, we need to enter a security code on the client device?
If I read the user-guide it is said that the opmode transition option is only supported on the wpa3-sae-aes opmode ?
Is the enterprise version by default backwards compatible ? without the opmode transition?
Kind regards,
