Aruba Apps
Wrong series ip address
  • 1.  Wrong series ip address
    Posted Sep 13, 2021 08:10 AM
    Hello team,
    In vlan 80 We are getting 192.168.0.x series ip instead of 10.2.80.x
    When i give static ip to the system everything is working fine but automatically vlan 80 is giving 192.168.0.x series ip . We are using Aruba 2930f switch.
    I am using a Aruba switch for troubleshooting the issue
    Port 1  is uplink port and on port 2 is untagged in vlan 80 where my laptop is connected and my laptop is getting 192.168.0.10 ip and no internet.
    Please help
    Shivam Ojha
  • 2.  RE: Wrong series ip address
    Posted Sep 13, 2021 11:38 AM
    Can you use ipconfig /all on your Windows? That will include the DHCP server information. Do you have a DHCP server in that VLAN that offers IP addresses in the 10.2.80.x range?
    If there is no DHCP server in a VLAN, Windows may have a static fallback IP, and that may be what you see. Wireshark running while you disconnect and re-connect the client should also show where the IP is coming from.
