What you could do is connect a laptop running wireshark to the port, then see the DHCP requests and responses and what device/MAC address is responding.
Most likely, there is another device on your network acting as DHCP server, if you don't recognize the IP range from another VLAN in use.
Also, are you sure the IP is received through DHCP? If a user changed the network config on the computer to a static IP, that IP is used of course.
Original Message:
Sent: Sep 07, 2021 10:49 AM
Subject: Wrong series ip address
Port is configured as untagged vlan 80 and vlan 80 is tagged on Uplink port. It was working properly since 3 months . problem started from yesterday.
Original Message:
Sent: 9/7/2021 6:09:00 AM
Subject: RE: Wrong series ip address
Hello Shivam, you wrote: "We have configured a switch" but you didn't specify which one so what switch model are you referring to exactly? you should provide a lot more details to help us helping you (as Craig already wrote).
Davide Poletto
Original Message:
Sent: Sep 07, 2021 01:51 AM
Hello team,
We have configured a switch with 10.serias ip address but some clients are getting 192.168.00 series ip address I checked the configuration there is no configuration related to 192.168.0.0 series .what should I check
Shivam Ojha
