If I understand it correctly the internal uplink and downlink ports on the WES zl-module is a virtual 1 Gbps link (full duplex I suppuse) and the total unencrypted throughput is 2 Gbps.
However, if I am using the full amount of Radio Ports for the ZL module, 156, and for example, on all these RP:s there are one single client associeted and downloading data from some servers on the wired network, and we assume that wireless stations get something like 20 mbps in actual data transfer speed, then the total amount of traffic passing through the WESM would be 156 RP * 20 mbps = 3120 mbps.
Does this mean that the WES module introduces a potential bottleneck if all attached RP:s is sending data at the same moment in time?
Naturly traffic patterns does vary in a real network, but do I think correctly that the WES module only can support around 50 RP with an outgoing stream to the wireless network of around 20 mbps?
