In the past few months , I have seen numerous issues with paging ranging from the groups to Multicast to switch issues to setting up hardware ( using a 2102 speaker inside the tel for the page leads for Paging on a remote end of a building ) . There can be numerous issues with internal and external setup but if you follow the steps below , it should help for internal paging . Also try to remember that we page at layer 2 mac address . Flooding the network with IGMP requests and audio to the device that can pick up the requests . Make sure to set up your IP address , Subnet and Default gateway on the NBX . Most imprtant for the Subnet and the Gateway to be set up correctly as well .
1. Try and find a hub ( an older style non intelligent ) . Plug this in and page . If paging works thru the hub then its a safe bet to say the issue is probably Multicast / IGMP related .
2. If it does not work , then I am of old school - upgrade to R6.0.63 and make sure we have the latest code . Check again
3. If it still does not work then we would need to have a case opened then Traces and logs .
My best guess ? Something on the network - more specifically IGMP . Try this test out and I would like to hear back from you if it works .
Hope this helps !
