  • 1.  zone ssid
    Posted Oct 29, 2015 12:57 PM
    Hi All,
    I need some advise regarding ssid zoning.  Say for example we have 3 IAP-103 access points in a cluster. AP1, AP2 and AP3
    We have 2 SSIDs, example "Staff" and "Guest"
    How do I configure the AP1 to broadcast the "Staff" and "Guest" SSIDs, AP2 to broadcast only the "Guest" SSID and AP3 to broadcast the only the "Staff" SSID?
    Thanks!
  • 2.  RE: zone ssid
    Posted Oct 29, 2015 02:22 PM
    With the current way zones work I do not think this is possible. From the guide:
    - An IAP can belong to only one zone and only one zone can be configured on an SSID.
    - If an SSID belongs to a zone, all IAPs in this zone can broadcast this SSID. If no IAP belongs to the zone configured on the SSID, the SSID is not broadcast.
    - If an SSID does not belong to any zone, all IAPs can broadcast this SSID.
    I also tried to create the same SSID twice and assign each instance of the SSID to a different zone, but it will not allow duplicate SSID to be created even with a different zone.
  • 3.  RE: zone ssid
    Posted Oct 29, 2015 02:31 PM
    Thanks for the prompt reply.
    This was my conclusion too, I was hoping I interpreted the user guide
    incorrectly. I guess I'm going to have to create a new ssid and zone. But
    this will cause some other headaches with the applications/ devices!
