There is guidance in the VSG. For such a large amount, using templates may be the way to go, or use templates to get switches connected, then move to UI group.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Feb 13, 2025 07:07 AM
Subject: ZTP for CX 6000
Dear Experts,
We have a mass deployment of 6000 switches for different sites. We want to configure 2 Vlans, one for data and another one (not default Vlan) for mgmt. When i am using group based configuration i dont see any option to assign any ip address for SVI. I am kinda confused how to approach it so that when the installer connects the switch to router (also acting as dhcp server) what shall happen next? switch should get ip on Vlan 1 and then we access it via cloud and do the device level config?
