Access Points
Highlighted
Controller-Side Errors
A controller side error is normally a frame that the interface sees that he cannot interpret in part or whole. Make sure the infrastructure side configuration is as clean as possible. If it continues, open a case so that they can interpret what is happening.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba Technical Webinars
Highlighted
Occasional Contributor I
MTU size
I had the exact same error - 3.4.2.2 on all 3xxx series boxes about 5 months ago.
The issue manifested itself when Mac's came onto the network.
Changing the MTU to 1500 resolved this for us. Tech support had us disable opportunistic key caching as well (though I doubt this was related).
Highlighted
Same Error - fix in 3.4.2.4
We also have AP that were continuously rebooting everyday. We upgraded our Controller 3 times, and finally Version 3.4.2.4 came to the rescue.
On 3.4.2.3
controller #show ap debug system-status ap-name
Reboot Information
Reboot caused by kernel page fault at virtual address 00000000, epc == 00000000, ra == 80126420
Before 3.4.2.3 - No reboot information
Highlighted
So what does this tell you?
Is the kernel error the fault of the AP? The controller? Something else?
Thanks!
