AP Provisioning
Thanks for the advice Collin!
I changed the controller-ip to one that is directly connected to the Access Point private network and configured an access port directly to that vlan. GRE's and PAPI's are stable. One issue that I am experiencing for a little while now.....When I provision new AP 125's some do not provision correctly and they constantly reboot. I copied and pasted the error below, and created a support ticket with Aruba, but wanted to see if anyone has come across this (Kernel issue):
eth0: Link down
secure_jack_link_state_change: Error finding device eth0
bonding: bond0: link status definitely down for interface eth0, disabling it
bonding: bond0: now running without any active interface !
eth0: 100Mbs Full duplex, port 1, queue 1
bonding: bond0: link status definitely up for interface eth0.
bonding: bond0: making interface eth0 the new active one.
asap_gre_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from xxx.xxx.xxx.xxx <6>for vap 0:1
asap_gre_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from xxx.xxx.xxx.xxx <6>for vap 0:2
asap_gre_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from xxx.xxx.xxx.xxx <6>for vap 1:0
asap_gre_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from xxx.xxx.xxx.xxx <6>for vap 1:1
asap_gre_err: Received ICMP (DEST_UNREACH, PROT_UNREACH) from xxx.xxx.xxx.xxx <6>for vap 1:2
CPU 0 Unable to handle kernel paging request at virtual address 000000000000b076, epc == ffffffff802f40b4, ra == c00000000030ec68
Oops:
If I provisioned 14 AP 125's for a building, 2 - 4 AP's would constantly reboot after provisioning and render the AP useless. Anyone have ideas??
IP address
Luca,
Is the blacked-out IP address the ip address of the controller? Is it the public or private address?
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba Technical Webinars
IP
Colin,
Yes, and it is in the same private network/subnet as the AP's.
Unreachable
Luca,
My guesses are not as good as Aruba support. I hope that you don't have ICMP blocked on the controller port, is all I would check. Besides that, support will provide your best chance at resolving this.
Re: AP125 issue
Luca - Did you ever resolve this? I'm seeing ICMP destination/port unreachables on one of my controllers as well and AP65s/70s are bouncing on and offline. I just opened a TAC case, but I was wondering if you add any success resolving this.
Thanks...
Re: AP125 issue
Mike - I opened a TAC case as well, but my AP 125's are not bootstrapping or rebooting. I see these ICMP errors when the AP 125's boot, but then they are able to establish a GRE tunnel and connect a few seconds later.
Luca
