Highlighted
Contributor I
Re: Remote Site AP
Hi Sir,
"show ap database" -
All ok, only 1 AP (the AP plant in other building) flag "I".
"show profile-errors" -
No profile-errors detected.
Can check with you, what are the lists of port that needed for controller to talk/establish connection to AP.
I suspect firewall issue. till now I have see no drop at firewall side.
Port that I allow are 8200, 8211, 514 & PPTP
Highlighted
Re: Remote Site AP
Hi Sir,
If you have a firewall between your sites, please look at the article here: http://airheads.arubanetworks.com/vBulletin/showthread.php?t=78
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
Highlighted
Contributor I
Re: Remote Site AP
wow.... Thanks man.
But what is LMS controlller means??
I running 2 controller 650 series with HA.
is my controller call "LMS Controller"?
Highlighted
Re: Remote Site AP
wow.... Thanks man.
The management ip address of each controller must be allowed as a destination. If you are running a VRRP, you need to add that ip address, as well.
Highlighted
Contributor I
Re: Remote Site AP
Yup I did...
So is my controller consider LMS, Master controller or Local Controller??
Highlighted
Re: Remote Site AP
Yup I did...
If you have only one controller, it would count as all three.
Highlighted
Contributor I
Re: Remote Site AP
Thanks for help....
I have solve my issue.
It was due to my firewall.
:D
View solution in original post
