Aruba Apps
Occasional Contributor I
Re: RAP-155 use same network wired name when configured more than 1 RAP
Sorry about the internal DNS, I intened to say we don't any name from DNS , when setting AP Group on Aruba controller , in Configuration we specificed the SSID name on Wireless LAN but no any name setting about Wired AP.
  Then I suspected that it will be used the same name from  SSID but for RAP-155 it was not as I expected.
Do you have any idea to specific the name for Wired AP?
Thank you
