ArubaOS and Controllers
Re: Next Gen PEF Disabled APs
type "show switchinfo" and make sure that switchip of the controller can be reached by the access points. It looks like they are initially discovering it and then being redirected to an ip address where they get lost.
type "show ap system-profile default" and see what the LMS-ip is.
ArubaOS 8.4 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
Sign up for Security Alerts
Aruba Technical Webinars
(ACU-ADM-APCTR) #show switchinfo
Hostname is ACU-ADM-APCTR
Location not configured
System Time:Wed Dec 1 15:46:00 CDT 2010
ArubaOS (MODEL: Aruba651-US), Version 5.0.2.1
Website: http://www.arubanetworks.com
Copyright (c) 2002-2010, Aruba Networks, Inc.
Compiled on 2010-09-30 at 12:44:26 PDT (build 25568) by p4build
ROM: System Bootstrap, Version CPBoot 1.0.0.0 (build 23274)
Built: 2010-01-19 11:11:41
Built by: p4build@re_client_23274
Switch uptime is 2 hours 5 minutes 38 seconds
Reboot Cause: User reboot.
Supervisor Card
Processor XLS 408 (revision B1) with 907M bytes of memory.
32K bytes of non-volatile configuration memory.
256M bytes of Supervisor Card System flash (model=NAND 256MB).
Config File: default.cfg
Boot Partition: PARTITION 0
VLAN1 is up line protocol is down
Hardware is CPU Interface, Interface address is 00:0B:86:64:AD:A0 (bia 00:0B:86:64:AD:A0)
Description: 802.1Q VLAN
Internet address is 10.1.186.1 255.255.255.0
Routing interface is enable, Forwarding mode is enable
Directed broadcast is disabled, BCMC Optimization disabled ProxyARP disabled
Encapsulation 802, loopback not set
MTU 1500 bytes
Last clearing of "show interface" counters 0 day 2 hr 5 min 38 sec
link status last changed 0 day 2 hr 5 min 38 sec
switchrole:master
Configuration Changed since last save
No crash information available.
(ACU-ADM-APCTR) #show ap system-profile default
AP system profile "default"
Parameter Value
LMS IP 192.168.123.2
Backup LMS IP N/A
LMS Preemption Disabled
LMS Hold-down Period 600 sec
Number of IPSEC retries 360
LED operating mode (AP-9x/AP-10x/AP-12x/RAP-5x only) normal
RF Band g
Double Encrypt Disabled
Native VLAN ID 30
SAP MTU N/A
Bootstrap threshold 8
Request Retry Interval 10 sec
Maximum Request Retries 10
Keepalive Interval 60 sec
Dump Server N/A
Telnet Disabled
SNMP sysContact N/A
AeroScout RTLS Server N/A
RTLS Server configuration N/A
Remote-AP DHCP Server VLAN N/A
Remote-AP DHCP Server Id 192.168.11.1
Remote-AP DHCP Default Router 192.168.11.1
Remote-AP DHCP DNS Server N/A
Remote-AP DHCP Pool Start 192.168.11.2
Remote-AP DHCP Pool End 192.168.11.254
Remote-AP DHCP Pool Netmask 255.255.255.0
Remote-AP DHCP Lease Time 0 days
Remote-AP Backup Ports Enabled
Remote-AP uplink total bandwidth 0 kbps
Remote-AP bw reservation 1 N/A
Remote-AP bw reservation 2 N/A
Remote-AP bw reservation 3 N/A
Heartbeat DSCP 0
Session ACL ap-uplink-acl
Corporate DNS Domain N/A
Maintenance Mode Disabled
WISPr Location-ID ISO Country Code N/A
WISPr Location-ID E.164 Country Code N/A
WISPr Location-ID E.164 Area Code N/A
WISPr Location-ID SSID/Zone N/A
WISPr Operator Name N/A
WISPr Location Name N/A
Remote-AP Local Network Access Disabled
The IP address 192.168.123.2 is what the APs are trying to reach. Is that an ip address on the controller?
That is the correct address.
Please open a case. There is much more to this.
I am glad it stumped you also, although this is my first encounter with Aruba, i'm thinking, man it cant be that hard! Everything worked fine until PEF-NG came along.
Well, it turns out i had inadvertently removed the trusted VLAN range on the controllers ethernet interface that the APs talk on.
