This community is currently in a read-only state due to a maintenance window. For more info click here
Highlighted
Re: Novell 802.1X
The logon process would be to get into the Windows device locally first, then connect using the GTC supplicant and that will give you the ip address to launch the Novell Client authentication. As mentioned before, the Juniper Odyssey client gives you probably one of the most transparent login experience with the least amount of backend configuration.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Video Knowledge Base
Remote Access Point Solution Guide
ArubaOS Consolidated Release Notes
ArubaOS 8 ViA VPN Solution Guide
