Cloud Managed Networks
Highlighted
empty json variable when using config templates for switches in Aruba Central
I have different switches using the same configuration template in Aruba Central. Some switches don't have untagged VLANS on their ports. But because i use variable for this untagged VLAN i get a template ERROR on the switches who don't use that untagged VLAN.
"vlan.508.untagged": "" doesn't work. I get no value ERROR. Null doesn't work either.
Anybody got experience with this. I think the only solution is to use different config templates for every switch. I'm not a json guru, so maybe you can do something else i don't know.
Highlighted
Moderator
Re: empty json variable when using config templates for switches in Aruba Central
Central templates admit %if variable% type of constructs precisely for this use case. Here are some examples:
If-endif
%if condition1=true%
routing-profile 10.10.1.0 255.255.255.0 10.10.1.255
%endif%
If-else-endif
routing-profile 10.40.0.0 255.255.255.0 10.40.0.255
%else%
routing-profile 10.20.1.0 255.255.255.0 10.20.1.255
%endif%
Nested if
routing-profile 10.10.0.0 255.255.255.0 10.10.0.255
   %if condition2=true%
   routing-profile 10.30.1.0 255.255.255.0 10.30.1.255
   %else%
   routing-profile 10.50.1.0 255.255.255.0 10.50.1.255
   %endif%
%else%
routing-profile 10.20.0.0 255.255.255.0 10.20.0.255
   %if condition3=true%
   routing-profile 10.70.1.0 255.255.255.0 10.70.1.255
   %else%
   routing-profile 10.40.1.0 255.255.255.0 10.40.1.255
   %endif%
%endif%
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
