Community Feedback
Occasional Contributor I
Guide for aruba switchs
Hi to everyone, this is my first post and came here because i have a big doubts. I adquire two switch and IAP 315 but when i try to configure throught web ui the thing it's a little strange for me. I try to configure a few vlan but when i try to check this and enter to the web ui again was not possible so i reset the switch. In the other switch i check the trunks and want to add ports to one trunk but the menu don't show anything.
My plan it's to do a few vlan throught the switchs and put the IAP probably with his one vlan but with the little i move i have big doubts so i wanna ask if some knows or have a good guide to do the configuration from zero because i can't find in the internet a good reference. I have some knowledge of networks
Thanks for your help.
Greetings.
MVP Expert
Re: Guide for aruba switchs
Hey hey glad you visited.
What switch models are they and what code versions?
Frequent Contributor I
The Aruba OS switch CLI organised into diff contexts or levels.
You can determine your current context from switch prompt, as below.
context                                CLI prompt
basic                                     switch>
 enable                                   switch #
global configuration                  switch(config)#
other commands context            switch (context(example(vlan-1))#
Example:
configured the vlan for untagged traffic on a port   vlan <vid> untagged <int-id-list>
global configuration                               untagged <int-id-list>
enable a port to carry tagged traffic for specefic vlans
vlan <vid> tagged <int-id-list>
global config context tagged <int-id-list>
you want to see vlan after config
show vlan
show vlan port <int-id-list>
save with write memory
Hey #RINO thanks for your reply the switch are:
Aruba 2930F 24G 4SFP
Aruba 2590 24G POE
And the IAP
IAP 315
THe idea is have the 2930F has a core and have some vlans to communicate between them and one vlan for the IAP. I try with the Web UI but i can get it. So if you know some videos or guide to follow or recommend use the CLI and where to start i can try.
Greetings and thanks.
I would recommend using CLI.
for the switches CLI Guide, you can download them from Aruba website, you can state the switch and the software version and then download the documentation
