Community Feedback
Problem with putty window size and aruba 2530
So currently I have an annoying problem with putty and my aruba 2530.
I want to change the size of the window so I can see more lines in the window (also called rows). The default amount of rows that is visible is 24.
When I change it to 30 the window size gets larger, and I can now see 30 rows, but the extra rows are simply black, and everything I type will still show on the default last row which is 24. So nothing changed.
I'm not having this issue with Cisco.
Anyone else have this issue?
Contributor I
Re: Problem with putty window size and aruba 2530
this is when you are connected using serial connection?
For serial connection, you can change the number of lines with:
terminal length 60
And for the width:
terminal width 200
