Community Feedback
Highlighted
MVP
misleading info when comparing APs @ arubanetworks.com
Not sure where to drop this little tidbit but hopefully someone reading this here can bring it to the attention of those that can adjust it?
When comparing APs eg. https://www.arubanetworks.com/products/networking/access-points/compare/#105106,195476,132904, the temperature is one of the specs you can compare.
All APs here list their operating temperature except the 500 series which lists their storage and transport temperature.
Not a huge deal as the actual spec sheet is clear (and correct) but this still feels like something that should be corrected.
Koen (ACMX #351 | ACDX #547 | ACCP)
-- Found a post helpful or important? Click the "Thumbs Up" icon to give kudos.
Accepted Solutions
Highlighted
Re: misleading info when comparing APs @ arubanetworks.com
I think we do it to pick up more business from countries at the north and south pole.  Just kidding, we will get someone to take a look.
ArubaOS 8.5 User Guide
InstantOS 8.5 User Guide
Airheads Knowledgebase
Airheads Learning Videos
Aruba Central Documentation
ArubaOS Consolidated Release Notes
Aruba Technical Webinars
View solution in original post
Highlighted
MVP Expert
Hah! Thanks, I will file a ticket to get that corrected. Should take a few days. Thanks for pointing this out.
Jerrod Howard
Distinguished Technologist, TME
All Replies
Highlighted
Highlighted
MVP Expert
Jerrod Howard
