Aruba Mobility Controller – How to Enable Logging “Physical link up” Messages
MVP Expert
MVP Expert
Q:
How is logging for the message, “Physical link up” enabled?
A:
By default network logging is enabled for level “Warning”. “Physical link up” messages are level "Informationa". The following example describes how to change the logging level.
(Standalone) *[mynode] #show logging level verbose
LOGGING LEVELS
Facility  Level     Sub Category  Process
arm       warnings     N/A           N/A
network   warnings  N/A           N/A <======
security  warnings    N/A           N/A
security  warnings  ids              N/A
security  warnings  ids-ap        N/A
system    warnings  N/A           N/A
user      warnings     N/A           N/A
wireless  warnings  N/A           N/A
(Standalone) *[mynode] (config) #logging network level informational
(Standalone) ^*[mynode] (config) #write me
LOGGING LEVELS
network   informational  N/A           N/A<======
security  warnings       i  ds-ap        N/A
(Standalone) *[mynode] #show log network 1000 | include "Physical link"
Jan 12 12:04:18 :209801:  <4077> <WARN> |fpapps|  Physical link down: port 0/0/0
Jan 12 12:04:18 :209801:  <4077> <WARN> |fpapps|  Physical link down: port 0/0/1
Jan 12 12:04:31 :209800:  <4077> <INFO> |fpapps|  Physical link up: port 0/0/0, full duplex, speed 1 Gbps
Jan 12 12:04:31 :209800:  <4077> <INFO> |fpapps|  Physical link up: port 0/0/1, full duplex, speed 1 Gbps​
Version history
Revision #:
2 of 2
Last update:
‎07-16-2019 04:04 PM
Updated by:
Labels (1)
Contributors
