Configuring Concurrent Sessions
MVP Expert
MVP Expert
Q:
How to limit the number of concurrent CLI login sessions?
A:
From AOS 8.2.2.0/8.3.0.2 and later, a check is added to limit the number of concurrent CLI sessions that an administrator account can maintain. If the admin user tries to create a new session after the maximum concurrent user sessions limit is reached, then the system displays an error message and does not allow the user to login although the login credentials entered are valid.
Note: This option can be configured from CLI only.
(MM) [mynode] (config) #mgmt-user test root max-concurrent-sessions 1
Password:********
Re-Type Password:********
(MM) ^[mynode] (config) #write memory
Saving Configuration...
Configuration Saved.
(MM) [mynode] #show mgmt-user
Management User Table
USER    PASSWD  ROLE              STATUS   PATH  Max-concurrent-sessions
admin   *****   root              ACTIVE         N/A
gokul   *****   ap-provisioning   ACTIVE         N/A
test    *****   root              ACTIVE         1
Verification:
(MM) [mynode] #show log errorlog 1
Aug 21 03:16:29 <aaa 125055>  <5954> <ERRS> |aaa|   Max allowed concurrent sessions reached for user: test
Version history
Revision #:
2 of 2
Last update:
‎02-14-2019 01:28 PM
Updated by:
Labels (1)
Contributors
