How many SSID/Networks can be configured in Rogue classification rules?
MVP Expert
MVP Expert
Q:
A:
We can configure upto 6 ssid/networks in ids ap-classification rules
CLI:
(Master) (config) #ids ap-classification-rule idsaprules
(Master) (IDS AP Classification Rule Profile "idsaprules") #ssid test1
(Master) (IDS AP Classification Rule Profile "idsaprules") #ssid test2
(Master) (IDS AP Classification Rule Profile "idsaprules") #ssid test3
(Master) (IDS AP Classification Rule Profile "idsaprules") #ssid test4
(Master) (IDS AP Classification Rule Profile "idsaprules") #ssid test5
(Master) (IDS AP Classification Rule Profile "idsaprules") #ssid test6
(Master) (IDS AP Classification Rule Profile "idsaprules") #classify-to-type neighbor
WebUi:
If we try to add more then 6 ssid/network it will through error message the list is full.
​​(Master) (IDS AP Classification Rule Profile "idsaprules") #ssid test7
List is full
Version history
Revision #:
2 of 2
Last update:
‎02-20-2019 04:01 PM
Updated by:
Labels (1)
Contributors
