How to Configure an Access-Point Using the AOS CLI
MVP Expert
MVP Expert
This article discusses how to configure an access point using the ArubaOS command line (CLI).
The following CLI commands configures the access point name and group.
********** Display access point database **********
(MM1) [mynode] #show ap database
AP Database
Name               Group           AP Type  IP Address   Status             Flags  Switch IP  Standby IP
ac:a3:1e:ca:57:f8  default         115      10.1.14.101  Up 6m:43s          2      10.0.20.2  0.0.0.0
********** Enter global configuration mode **********
(MM1) [mynode] #configure terminal
Enter Configuration commands, one per line. End with CNTL/Z
********** Enter access point configuration mode **********
(MM1) [mynode] (config) #provision-ap
********** Select access point to be configured **********
(MM1) [mynode] (config-submode)#read-bootinfo ap-name ac:a3:1e:ca:57:f8
********** Change access point name a group **********
(MM1) [mynode] (config-submode)#ap-name AP-3
NOTE: For cert RAP; ap-name (if specified) in RAP whitelist entry will take the highest preference
(MM1) [mynode] (config-submode)#ap-group West-Coast-APs
NOTE: For cert RAP; ap-group provisioned in RAP whitelist entry would take the highest preference
********** Save access point configuration and reboot **********
(MM1) [mynode] (config-submode)#reprovision ap-name ac:a3:1e:ca:57:f8
--- Access point reboots ---
AP Database
AP-3  West-Coast-APs     115      10.1.14.101  Up 6m:12s         2      10.0.10.2  0.0.0.0
Version history
Revision #:
1 of 1
Last update:
‎10-14-2018 02:06 PM
Updated by:
