How to manually adjust EIRP levels for AirMatch Solutions in ArubaOS 8.x?
MVP
MVP
Aruba Controllers and VM's should be running minimum AOS: 8.1.x and above
Starting from AOS: 8.1.x the 5 GHz (802.11a) and 2.4 GHZ (802.11g) radio profiles include an EIRP Offset parameter that allow you to manually adjust EIRP levels by defining an additional EIRP offset value (from -6 to 6 dB) that will be added to the AirMatch solution.
From WebUI:
For 2.4 GHz Radio:
1. Navigate to the Configuration > System page and select the Profiles tab.
2. Select RF Management
3. Select 2.4 GHz radio and go to the appropriate profile
4. Manually Set eirp-offset value:
5.  Click Submit.
6. Click Pending Changes.
7. In the Pending Changes window, select the check box and click Deploy changes.
For 5. GHz Radio:
3. Select 5 GHz radio and go to the appropriate profile
5.  Click Submit.
From CLI:
For 2.4 GHz Radio:
(Aruba7205Standalone8.x) [mynode] #configure terminal
Enter Configuration commands, one per line. End with CNTL/Z
(Aruba7205Standalone8.x) [mynode] (config) #rf dot11g-radio-profile test-g-radio-profile
(Aruba7205Standalone8.x) [mynode] (802.11g radio profile "test-g-radio-profile") #eirp-offset 4
(Aruba7205Standalone8.x) ^[mynode] (802.11g radio profile "test-g-radio-profile") #exit
(Aruba7205Standalone8.x) ^[mynode] (config) #write memory
Saving Configuration...
Partial configuration for /mm/mynode
Contents of : /flash/ccm/partial/3/p=sc=mynode.cfg
rf dot11g-radio-profile "test-g-radio-profile"
    eirp-offset 4
Configuration Saved.
For 5 GHz Radio:
(Aruba7205Standalone8.x) [mynode] (config) #rf dot11a-radio-profile test-a-radio-profile
(Aruba7205Standalone8.x) [mynode] (802.11a radio profile "test-a-radio-profile") #eirp-offset 2
(Aruba7205Standalone8.x) ^[mynode] (802.11a radio profile "test-a-radio-profile") #exit
rf dot11a-radio-profile "test-a-radio-profile"
    eirp-offset 2
For 2.4 GHz Radio:
(Aruba7205Standalone8.x) [mynode] #show rf dot11g-radio-profile "test-g-radio-profile"
Parameter                                      Value
Radio enable                                   Enabled
Mode                                           ap-mode
High throughput enable (radio)                 Enabled
Very high throughput rates enable (256-QAM)    Disabled
Channel                                        N/A
Transmit EIRP                                  15 dBm
Non-Wi-Fi Interference Immunity                2
Enable CSA                                     Disabled
CSA Count                                      4
Smart Antenna                                  Enabled
Advertise 802.11d and 802.11h Capabilities     Disabled
Spectrum Load Balancing                        Disabled
Spectrum Load Balancing Mode                   channel
Spectrum Load Balancing Update Interval (sec)  30 seconds
Spectrum Load Balancing Threshold (%)          20 percent
Spectrum Load Balancing Domain                 N/A
Beacon Period                                  100 msec
Beacon Regulate                                Disabled
Advertized regulatory max EIRP                 0
ARM/WIDS Override                              OFF
Reduce Cell Size (Rx Sensitivity)              0 dB
Energy Detect Threshold Offset                 0 dB
Management Frame Throttle interval             1 sec
Management Frame Throttle Limit                20
Maximum Distance                               0 meters
RX Sensitivity Threshold                       0 dB
RX Sensitivity Tuning Based Channel Reuse      disable
Protection for 802.11b Clients                 Enabled
Adaptive Radio Management (ARM) Profile        default-g
High-throughput Radio Profile                  default-g
AM Scanning Profile                            default
Max Channel Bandwidth                          40MHz
Min Channel Bandwidth                          20MHz
Min EIRP                                       6 dBm
Max EIRP                                       9 dBm
eirp-offset                                    4 dB
deploy-hour                                    N/A
For 5 GHz Radio:
(Aruba7205Standalone8.x) [mynode] #show rf dot11a-radio-profile "test-a-radio-profile"
Parameter                                      Value
Mode                                           ap-mode
Very high throughput enable (radio)            Enabled
Channel                                        N/A
Spur Immunity                                  0
Enable CSA                                     Disabled
CSA Count                                      4
Adaptive Radio Management (ARM) Profile        default-a
High-throughput Radio Profile                  default-a
Max Channel Bandwidth                          160MHz
Min Channel Bandwidth                          80MHz
Min EIRP                                       12 dBm
Max EIRP                                       18 dBm
eirp-offset                                    2 dB
deploy-hour                                    N/A
Version history
Revision #:
1 of 1
Last update:
‎03-21-2019 02:34 PM
Updated by:
