How to setup redundancy with ipsec over gre
MVP Expert
MVP Expert
To setup redundancy with ipsec over gre between two Master-Standby setups on different locations and allow specific VLAN(s) in it.
Create a non-routable L3 interface to act as GRE endpoint on the controllers.
Only one tunnel needs to be up at any time so that it does not form any loop.
Configure the peer-IP as VRRP IP on one master-standby setup and physical IP as peer-IP on the other master-standby setup.
On HQ-Master:
Create ipsec-map:
crypto-local ipsec-map To_DMZ 100
  peer-ip 10.0.0.1
  vlan 30
  src-net 192.168.30.0 255.255.255.0
  dst-net 192.168.10.0 255.255.255.0
  set transform-set "default-transform"
  pre-connect enable
  trusted enable
  uplink-failover disable
  force-natt disable
Create isakmp key:
crypto-local isakmp key "arubavpn123" address 10.0.0.0 netmask 255.255.255.0
Create a L3 interface for GRE-endpoint:
interface vlan 100
        ip address 192.168.30.2 255.255.255.0
        operstate up
Configure GRE tunnels. (Only one tunnel will be up at a time)
interface tunnel 100
        tunnel mode gre 1
        tunnel source vlan 100
        tunnel destination 192.168.10.2
        tunnel keepalive
        trusted
        tunnel vlan 1501
interface tunnel 101
        tunnel mode gre 1
        tunnel destination 192.168.10.3
        tunnel keepalive
        trusted
        tunnel vlan 1501
On HQ-Standby:
Create ipsec-map:
  peer-ip 10.0.0.1
  vlan 30
  pre-connect enable
  trusted disable
  force-natt disable
Create isakmp key:
interface vlan 100
        ip address 192.168.30.3 255.255.255.0
        operstate up
        tunnel mode gre 1
        tunnel keepalive
        trusted
        tunnel vlan 1501
        tunnel mode gre 1
        tunnel keepalive
        trusted
        tunnel vlan 1501
On DMZ-Master:
Create ipsec-map:
crypto-local ipsec-map To_HQ-Master 100
  peer-ip 30.0.0.2
  vlan 10
  src-net 192.168.10.0 255.255.255.0
  dst-net 192.168.30.2 255.255.255.255
  pre-connect disable
  trusted disable
  force-natt disable
crypto-local ipsec-map To_HQ-standby 100
  peer-ip 30.0.0.3
  vlan 10
  dst-net 192.168.30.3 255.255.255.255
  pre-connect disable
  trusted disable
  force-natt disable
Create isakmp key:
crypto-local isakmp key "arubavpn123" address 30.0.0.0 netmask 255.255.255.0
interface vlan 100
        ip address 192.168.10.2 255.255.255.0
        operstate up
        description "Tunnel Interface"
        tunnel mode gre 1
        tunnel destination 192.168.30.2
        tunnel keepalive
        trusted
        tunnel vlan 1501
        tunnel mode gre 1
        tunnel destination 192.168.30.3
        tunnel keepalive
        trusted
        tunnel vlan 1501
On DMZ-Standby:
Create ipsec-map:
crypto-local ipsec-map yas-master 100
  peer-ip 30.0.0.2
  vlan 10
  pre-connect enable
  trusted disable
  force-natt disable
crypto-local ipsec-map yas-standby 100
  peer-ip 30.0.0.3
  vlan 10
  pre-connect enable
  trusted disable
  force-natt disable
Create isakmp key:
interface vlan 100
        ip address 192.168.10.3 255.255.255.0
        operstate up
        tunnel mode gre 1
        tunnel keepalive
        trusted
        tunnel vlan 1501
        tunnel mode gre 1
        tunnel keepalive
        trusted
        tunnel vlan 1501
(Aruba7010) #show crypto ipsec sa
IPSEC SA Active Session Information
Initiator IP     Responder IP     InitiatorID         ResponderID         Flags    Start Time      Inner IP
30.0.0.2          10.0.0.2              30.0.0.2/32          10.0.0.2/32/32      T      Nov 30 05:46:38     -
(Aruba7010) (config) #show ip interface brief
Interface                   IP Address / IP Netmask        Admin   Protocol
tunnel 101                  unassigned / unassigned        up      up
Version history
Revision #:
2 of 2
Last update:
‎03-15-2019 01:22 PM
Updated by:
Labels (1)
Contributors
