Q:
How can we identify the highest and current temperature of Aruba acesss points to avoid getting over heat and damage?
Starting from 8.6.0.0, thermal sensors available in the 11ax Access points hardware will trigger the AP to switch to thermal shutdown mode with flashing red system LED on when any of the sensor’s temperature exceeds the specific high threshold defined for it.
When AP is in overheat status, AP will do rebootstrap and will not connect to the controller until AP it is in cool down status.
Below are the command helps to identify the temperature level,
(host) #show ap power-mgmt-statistics ap-name 00:4e:35:c4:47:06 AP Power Mgmt Status, Last update at 2019-09-26 16:43:13 -------------------------------------------------------- Attr Value ---- ----- LLDP Granted Power Eth 0: 23.3 Eth 1: 23.3 LLDP Request Power Eth 0: 23.3 Eth 1: 23.3 Temperature Highest temperature: 52°C, Lowest temperature: 48°C, Current temperature: 50°C Power Supply POE-AT USB Status USB Knob: Auto, USB Status: Disabled PSE Status N.A. ETH Status Eth 0:Enabled. Eth 1:Disabled. G-radio Chain 4*4 G-radio Enable Enabled G-radio Power Full Power A-radio Chain 4*4 A-radio Enable Enabled A-radio Power Full Power CPU Throttle 100% Power Consumption 7.6W IPM Enable Disabled
