How to transfer files between controllers using SCP?
MVP
MVP
How to transfer files between controller using SCP service on controller itself?
Use case, customer may not have file transfer servers in his or her setup and in such case, we can use SCP service on controller to transfer files between controllers.
Enable SCP service on the controller where the file needs to be send to as that would act as the SCP server. No need to enable SCP service on the controller from where file is being sent.
To check if SCP service is enabled;
(MD) [MDC] #show scp
service scp is disabled
To enable SCP service:
(MM) [00:1a:1e:x:x:x] (config) #service SCP
(MM) ^[00:1a:1e:x:x:x] (config) #show configuration pending
service scp
To disable SCP service;
(MM) ^[00:1a:1e:x:x:x] (config) #no service scp
service scp is enabled
Using local mgmt user:
(MM) [mynode] (config) #copy flash: mac_addr.cfg scp: <2nd controller ip> scp mac_addr.cfg
Password:********
Secure file copy:
Press 'q' to abort.
File uploaded successfully
(MM) [mynode] (config) #copy flash: mac_addr.cfg scp: <2nd controller ip> admin mac_addr-1.cfg
Password:********
Secure file copy:
Press 'q' to abort.
Dir output from 2nd controller
-rw-r--r--    1 root     root           18 Apr  9 03:02 mac_addr-1.cfg         <<<<<<<<<< filed copied using username admin
-rw-r--r--    1 root     root           18 Apr  9 03:01 mac_addr.cfg           <<<<<<<<<< filed copied using username scp
This does not work if management user is authenticated against external server.
(MM) [mynode] (config) #copy flash: mac_addr.cfg scp: <2nd controller ip> <AD username> mac_addr-2.cfg
Password:**********
Secure file copy:
Press 'q' to abort.
Error copying file:
Permission denied: wrong username or password
On MD, we see authentication failure for AD username;
Apr 9 03:01:05 :199801:  <22234> <INFO> |sshd|  Accepted password for scp from x.x.x.x port 49756 ssh2
Apr 9 03:02:18 :199801:  <22538> <INFO> |sshd|  Accepted password for admin from x.x.x.x port 51242 ssh2
Apr 9 03:03:13 :125022:  <6894> <WARN> |aaa|  Authentication failed for User <AD username>, Logged in from x.x.x.x port 22, Connecting to x.x.x.x port 52402 connection type SSH
Apr 9 03:03:13 :199801:  <22814> <INFO> |sshd|  Failed password for <AD username> from x.x.x.x port 52402 ssh2
Version history
Revision #:
2 of 2
Last update:
3 weeks ago
Updated by:
Labels (1)
Contributors
