This article describes how to use packet capture utility to capture and display DNS packets, sent and received from the Mobility Controller.
In the following example, the Mobility Controller is configured for DNS domain lookup. The CLI “packet-capture controlpath” command, captures packet destined for the managed device for protocols TCP and UDP with port 53.
********** DNS configuration/verification **********
(Mobility-Controller) *[mynode] (config) #ip domain lookup (Mobility-Controller) *[mynode] (config) #ip domain-name global.tslabs.hpecorp.net (Mobility-Controller) *[mynode] (config) #ip name-server 10.252.248.9 (Mobility-Controller) *[mynode] (config) #ip name-server 10.252.248.10
(Mobility-Controller) *[mynode] #show ip domain-name IP domain lookup: Enabled IPv6 domain lookup: Enabled IP Host.Domain name: Mobility-Controller.global.tslabs.hpecorp.net DNS servers =========== 10.252.248.9 10.252.248.10 10.181.253.40 *
********** DNS packets destined for the managed device **********
(Mobility-Controller) *[mynode] #packet-capture controlpath tcp 53 (Mobility-Controller) *[mynode] #packet-capture controlpath udp 53
(Mobility-Controller) *[mynode] #show packet-capture Active Capture Destination -------------------------- Destination Disabled Active Capture (Controlpath) ---------------------------- Interprocess Disabled Sysmsg Disabled TCP Enabled Ports: 53 UDP Enabled Ports: 53 Other Disabled
A DNS client (192.168.200.1) made a query for the name support.arubanetworks.com. This query was sent to the name server (10.252.248.9.53) and the response was forwarded to the DNS client.
(Mobility-Controller) *[mynode] #show packet-capture controlpath-pcap 14:48:02.704422 IP 192.168.200.1.50961 > 192.168.200.2.53: 21+ A? support.arubanetworks.com. (43) 14:48:02.704620 IP 10.181.243.118.10951 > 10.252.248.9.53: 13618+ A? support.arubanetworks.com. (43) 14:48:02.757313 IP 10.252.248.9.53 > 10.181.243.118.10951: 13618 1/0/0 A 52.8.87.99 (59) 14:48:02.757431 IP 192.168.200.2.53 > 192.168.200.1.50961: 21 1/0/0 A 52.8.87.99 (59)
