If controller reboots unexpectedly
MVP
MVP
Q:
What steps to be performed if controller reboots unexpectedly?
A:
You can follow below steps if controller was rebooted
1. Check the reason of reboot using command
#show switchinfo
Hostname is arubalab-MD
System Time:Wed May  6 17:41:25 EDT 2020
No crash information available.                                             ------> Check if there is any crash available
No kernel crash information available.
Reboot Cause: User reboot (Intent:cause:register 78:86:50:60)
show syslocation
Location not configured
show version
ArubaOS (MODEL: Aruba7010-US), Version 8.5.0.6
Website: http://www.arubanetworks.com
(c) Copyright 2020 Hewlett Packard Enterprise Development LP.
Compiled on 2020-01-24 at 06:35:12 UTC (build 74058) by p4build
ROM: System Bootstrap, Version CPBoot 1.0.7.0 (build 65676)
Built: 2018-07-06 04:23:32
Built by: p4build@re_client_65676
Switch uptime is 2 days 21 hours 24 minutes 22 seconds
Reboot Cause: User reboot (Intent:cause:register 78:86:50:60)                    ----> Check the reason
Supervisor Card
Processor (XLP208 Rev B1 (Secure Boot) , 800 MHz) with 3797M bytes of memory.
32K bytes of non-volatile configuration memory.
1936M bytes of Supervisor Card system flash.
2. If we have crash available, then extarct crash and copy it out of controller
#tar crash
#copy flash: crash.tar tftp: <ip address of tftp server> crash.tar
3. Check if any process is stuck on controller
#show process monitor statistics
4. Check for cpu and memory
#show cpuload
#show memory
5. Collect controller's logs.tar and copy out of controller
#tar logs tech-support
#copy flash: logs.tar tftp: <ip address of tftp server> logs.tar
Once you have all the logs and outputs collected, open TAC ticket for further analysis.
Version history
Revision #:
2 of 2
Last update:
‎07-03-2020 06:25 PM
Updated by:
Labels (1)
Contributors
