Roaming-triggered Interim Radius Accounting message
MVP Expert
MVP Expert
Controller to trigger "Interim Radius Accounting message " when th client roams from one AP to another AP.
This feature requires AOS to notify RADIUS server(s) about roaming events on wireless clients by using RADIUS Accounting protocol (RFC-2866). It will allow customers to track current location of clients by examining their RAIDUS accounting servers.
AOS Roaming RADIUS Accounting Service creates an Accounting-Session for each wireless client. This session beginning with a RADIUS Start Accounting record, following with zero or more RADIUS Interim-Update Accounting records, and ending with a RADIUS Stop Accounting record. This RADIUS Interim-Update Accounting record is triggered whenever the wireless client roams to a different AP
CLI:
(config) #aaa profile 643aaa
(AAA Profile "643aaa") #radius-roam-accounting
#show aaa profile 643aaa
Parameter                             Value
RADIUS Accounting Server Group        cppm
RADIUS Roaming Accounting             Enabled
RADIUS Interim Accounting             Enabled
Enable the below logging
•logging level debugging security
•logging level debugging security process authmgr subcat aaa
Existing show command like “show auth-tracebuf” and “show log security” can be used to determine roaming triggered radius interim packet.
#show user
Users
    IP             MAC            Name     Role           Age(d:h:m)  Auth    VPN link  AP name          Roaming             Essid/Bssid/Phy                         Profile  Forward mode
10.15.24.244  60:03:08:98:25:98  smoke1    authenticated  00:00:03    802.1x   ap205h   Wireless  testroam/6c:f3:7f:7f:96:10/a-VHT  testaaa  tunnel
Aruba7210) #show auth-tracebuf  count 10
Auth Trace Buffer
Mar 14 03:29:31  rad-acct-start            ->  60:03:08:98:25:98      9c:1c:12:97:55:d0/win  -   -
Mar 14 03:29:47  ap-up                           *                                         6c:f3:7f:7f:96:10            -   -    wpa2 aes
Mar 14 03:29:54  station-down              *  60:03:08:98:25:98      9c:1c:12:97:55:d0          -   -
Mar 14 03:30:01  station-up                    *  60:03:08:98:25:98      6c:f3:7f:7f:96:10            -   -    wpa2 aes
Mar 14 03:30:01  eap-id-req                   <-  60:03:08:98:25:98     6c:f3:7f:7f:96:10            1   5
Mar 14 03:30:01  rad-acct-int-update   ->  60:03:08:98:25:98      6c:f3:7f:7f:96:10/win   -   -
(Aruba7205) #show log security 100 | include aaa
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2307] Sending radius request to win:10.15.24.102:1813 id:14,len:281
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  User-Name: smoke1
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  NAS-IP-Address: 10.15.24.14
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  NAS-Port-Id: 0
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  NAS-Port-Type: Wireless-IEEE802.11
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Acct-Session-Id: smoke1600308982598-58C7D41C-4FDE
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Event-Timestamp: 03/14/2017 11:30:02
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Acct-Multi-Session-Id: 600308982598-0000000001
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Framed-IP-Address: 10.15.24.244
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Calling-Station-Id: 600308982598
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Called-Station-Id: 000B86B73C07
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Class: Q\304\006Y
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Acct-Delay-Time: 0
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Aruba-Essid-Name: testroam
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Aruba-Location-Id: ap205h
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Aruba-AP-Group: default
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Aruba-User-Role: authenticated
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Aruba-User-Vlan: 24
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2321]  Aruba-Device-Type: (VSA with invaild length - Don't send it)
Mar 14 03:30:02 :121031:  <5392> <DBUG> |authmgr| |aaa| [rc_server.c:2323]  Acct-Status-Type: Interim-Update
Mar 14 03:30:02 :121031:  <4107> <DBUG> |authmgr| |aaa| [rc_request.c:79] Find Request: id=14, srv=10.15.24.102, fd=65
Mar 14 03:30:02 :121031:  <4107> <DBUG> |authmgr| |aaa| [rc_request.c:85]  Current entry: srv=10.15.24.102, fd=65
Mar 14 03:30:02 :121031:  <4107> <DBUG> |authmgr| |aaa| [rc_request.c:40] Del Request: id=14, srv=10.15.24.102, fd=65
Mar 14 03:30:02 :121031:  <4107> <DBUG> |authmgr| |aaa| [rc_api.c:1229] Authentication Successful
Version history
Revision #:
2 of 2
Last update:
‎03-21-2019 11:31 AM
Updated by:
Labels (1)
Contributors
