Support for Enabling Specific Ciphers and MAC for SSH
MVP Expert
MVP Expert
Does Aruba Support enabling Specific Ciphers and MAC for SSH ?
ArubaOS supports the following cipher encryptions and MAC algorithms for SSH authentication on the controller:
1. AES-CBC (cipher)
2. AES-CTR (cipher)
3. HMAC-SHA1 (MAC)
4. HMAC-SHA1-96 (MAC)
By default, all the algorithms are enabled in ArubaOS.
Starting from ArubaOS 6.5.4.4, the controller allows you to enable or disable a specific cipher or the HMAC-SHA1-96 authentication algorithm by using the WebUI or the CLI.
WebUI:
1. Navigate to the Configuration > Management > General page.
2. Under SSH (Secure Shell) Authentication Method > Encryption, select AES-CBC, AES-CTR, or Both.
3. Under SSH (Secure Shell) Authentication Method > Authentication, select HMAC-SHA1-96.
CLI:
(Aruba) (config) #ssh disable-ciphers ?
aes-cbc                 Disable AES-CBC. AES-CTR will be enabled.
aes-ctr                 Disable AES-CTR. AES-CBC will be enabled.
(local2) (config) #ssh disable-mac ?
hmac-sha1-96            Disable hmac-sha1-96.
1. Default SSH Configuration:
(Aruba) (config) #show ssh
SSH Settings:
DSA                                                            Enabled
Mgmt User Authentication Method     username/password
Ciphers                                                      aes128-cbc,aes256-cbc,aes128-ctr,aes192-ctr,aes256-ctr
MACs                                                          hmac-sha1,hmac-sha1-96
As per pcap, Server: Key exchange Init shows the following :
2. We will disable one of the ciphers & mac as shown below :
(Aruba) (config) #ssh disable-mac hmac-sha1-96
(Aruba) (config) #ssh disable-ciphers aes-cbc
SSH Settings:
DSA                                                            Enabled
Ciphers                                                      aes128-ctr,aes192-ctr,aes256-ctr
MACs                                                         hmac-sha1
As per pcap, Server: Key exchange Init shows that aes-cbc & hmac-sha1-96 is no longer enabled.
Version history
Revision #:
2 of 2
Last update:
‎11-06-2018 03:37 PM
Updated by:
Labels (1)
Contributors
